13600k P cores stuck at 2500mhz
I had to update the bios to 2204 due to the cpu being a 13th gen. I also did the ME update. I guess I will redo the update. Thanks I will let you know.
Followed your advice updated the MEUpdateTool Version 16.1.25.2020 down loaded from the Asus Driver website for Strix Z690..
HWmonitor reports back P core 2500mhz @Max and E cores 3901 @ max.
Sounds like maybe the P core turbo is turned off, but it should be on by default. Did you try my above suggestion about clear CMOS & load defaults?
Do your scores in stuff like 3D Mark and cinebench reflect that the CPU is underclocked?
Yes I cleared CMOS and loaded defaults
Check in Bios (CPU-powermanagement control) is enabled.
Cinebench R23 score Single 981 - Multi core 14696
Max cpu temp 36C on HWmonitor
Hi just ran intel ETU Optimiser set to P 55x and E 43x max temp 55C
1
2
I've never heard of this program so not sure what I'm looking at.
Overclock3D have a review of the 13600K and from the review, you should be getting a much higher score. Hopefully someone more familiar with Cinebench can confirm that.
May have to re-install Window 11, what do you think
If it's not a big deal, then sure. No harm in it.
What Windows power plan are you on?
Go to the bios and then go advanced > CPU configuration > CPU power management control > and make sure turbo is set to enable.
Windows Power Plan set to Balanced and setting both at 15minutes.
Turbo within Bios is set at Enabled.
I will look at the Pump mounting and redo. I will advise. Thank you
Hi Just to advise I re-installed pump header with new thermal paste and added second cpu power lead. CPU-Z shows 5100mhz. great fixed thanks a lot for your help
