- 18 Nov 2016
- Airdrie, Scotland.
Hi there, I hope all is well.
I just recently upgraded to a 13600KF a few weeks ago and have a quick question regarding the voltages. I'm using an ASRock Z690 Steel Legend board. (BIOS updated for 13th gen CPU). I don't overclock.
TL;DR: 13600KF on stock clocks hit 1.5v on a few occasions. Has it been hurt?
Upon installation of the CPU, I noticed right away some insanely high load temps when gaming (80 degrees and into the 90's). Cooling was not the issue. I read that voltages could be the culprit so I monitored them. When gaming, the voltage was consistently in the 1.35-1.45 range, and actually hit 1.5v on a couple of occasions.
After resetting BIOS, ensuring correct PL1/2 power limits were set, and trying numerous things to no avail, a BIOS update to a more recent version (which quoted improved CPU microcode etc) thankfully fixed it. The voltages have dropped to their normal acceptable range, and temperatures have also dropped to where they should be (around 65 average under gaming load, high 30's when idle). I presume there were errors in the BIOS leading to it applying an OC voltage when it wasn't needed? This is my first ever K processor so this is all new to me.
I've been using it for a couple of weeks now and all seems well, its performing perfectly fine as far as I can tell, however I'm now questioning if I've degraded the CPU at all with those brief times where it hit 1.5V? Prior to fixing it with the BIOS update, there were a few occasions where the CPU hit 100 degrees during testing on CineBench and it thermal throttled aswell.
Should I have anything to worry about? Are there any means of testing it to see if something has been degraded? Am I overthinking it and worrying about nothing and need to take a chill pill?
Any help or advice is much appreciated
