do a search iv done an extensive guide into this rez.
best way to get it working is to use vga connection, hdmi will only support 1280x720 or 1900x1080
care to post a linky? Oh and you're wrong btw on the supported res's.
i had to make a custom monitor driver using powerstrip to get that rez available.
very rare iv seen that happen though, using HDMI the image goes through the tvs internal scaler and get rescaled to fit, and its not a pretty sight. best to use vga to get the sharpest image possible.
Nah it accepts 1920x1080 but it doesn't actually run at that resolution, my parents Panasonic downstairs is the same, it accepts the single and downscales it to the native resolution of the TV.My Panasonic Viera 26" TX26LXD70, is through HDMI and the max i can set is 1920,1080 i can also have any other resolution i like. Its great scales anything even 1920,1080 with 1:1 Pixel Mapping.
1366x768 is not a real res as 1366 is not a 32-bit number
