13700k v 13600K
11 Jul 2003
Telford//west mids
Will be used for gaming is the 13700k worth the extra over the 13600k as im building a z790 DDR5 Pc for a friend.
Thanks.
Depends on the res they'll be playing at, I'd personally save the money or put the uplift towards something else and get the 13600k
34" Widescreen 3440x1440 120hzz 3090ti
13600K is fine for higher res. As you increase res you put more pressure on the GPU than CPU. That being said, if you just want a 13700K and money isn't an issue, go for it too. They are both good CPUs.
index.php
May as well go for the 13600k not much in them on that graf,thanks :)
