I'm just laughing at the 100mhz "OC" over stock. I wonder how much unnessary voltage they pumped into that.
A lot...
I still don't get how they made this review. I have the same chip, same AIO, same contact frame, way worse ram, worse mobo and I got 40k in R23 drawing over 346w not thermal throttling boosting with "normal" turbo settings. The all core run like he did didn't even hit 90c. Did he mess up the TVB settings in a previous bench or just tried to tweak with it and hit 1,5v in CB? That's the most simple reason I can think of. I agree with @Bencher, prob done on purpose.
YT reviewers are truly something else.
He thermal throttled a stock 13600k on a 360mm running R23 as well. Pure clown material.
In games, yes, ive been saying it all this time. For heavy mt workloads the 7950x is more efficient at same wattage, not by much but it has the lead. In mixed workloads (autocad photoshop premiere etc.) intel has a huge lead in efficiency13900KS wiping the floor with Zen 4. A generational difference. Now to see how this will hold up vs 7800X3D next month... I'm still hopeful Zen 4 3D can get near it.
Intel Core i9-13900KS im Test: Der TDP-Hammer mit der 6.000-Megahertz-Ladung
Auf dieser Seite besprechen wir die neuen Bewertungsgrundlagen, die wir für CPU-Generationen ab Alder Lake getroffen haben. Es folgen die Benchmarks in Spielen sowie Anwendungen. Die Beobachtung wird durch einen Index abgeschlossen, der die Leistung des Prozessors im CPU-Limit mit einer...www.pcgameshardware.de
Τhe resolution is irrelevant. The point is to remove the GPU bottleneck. If you can remove the gpu bottleneck at 4k or even 8k then the tests would be done at 4k or 8k and the results would be the exact same.720p with a 4090. Only fanboys give a ****.
And it still loses to a 12900k running at 4400! InsaneAnd 720p is hugely memory bandwidth hungry and zen is running at 5200 lol.
So in order to save time, instead of trying every single resolution to see if you are gpu bound, why not just run the test at 720p and be done with it?
But its pretty easy to settle whether their benchmarks are true or fake. We have the hardware they use, we can test it. Ive personally asked repeatedly but people with amd cpus are not willing.
The only game I've managed to test is cp2077, the ingame benchmark, there was about a 32fps difference in aveages and arond 40% in minimums between a tuned 7950x and a stock 13900k.
But again, choose any of the games from the review you found suspect and ill benchmark it on my 13900k,and lets pray someone else will do the same on his zen 4. If we end up with completely different results then ill stop using that site obviously
Dont we have people here with Zen 4 or the 3d and a high end gpu? I mean come on now, that's just dodging, which is common tbf, whenever im asking for amd users to post a bench they just disappear99.9% of people don't have that hardware, so that's convenient....
Actually i just checked, their numbers on cyberpunk are pretty spot on regarding the 13900k and the 7950x. In minimums the 7950x even with tuned 6400 ram struggles to hit 80 while the 13900k casually hits 100. So at leastt the numbers in cyberpunk are pretty accurate99.9999% of people don't have that hardware, so that's convenient....
