As is my horrid luck when it comes to buying monitors, I tried somewhere else this time around instead and bought a new monitor from them (regardless of circumstance, no hinting at competitors).
The first one was returned as it had various faults and I opted for a direct replacement which they did, unfortunately the new replacement also had a fault although it is much more difficult to identify (it is apparently a known fault with this particular Acer monitor I bought) where by every few hours the screen will flash up some kind of artifacts usually in the form of 2 or 3 vertical lines, happens in the blink of the eye.
I know it is the monitor because I have tried different cables, tried it with a different PC and well others have also mentioned this and so it seems a wide scale problem / luck of the draw whether you are affected by it.
Anyway, this new replacement was sent to me on Thursday last week and they collected it to send back on the Tuesday. I explained to them that it could be quite difficult to capture the screen flash as the longest it went was several hours. I also asked how would they test it such as video the screen that sort of thing but didn't really get an answer for that other than they will use 3 days to test it.
In the event they determine the monitor is not faulty and attempt to return it back to me (which on the contrary I know it is faulty), do I have rights to cancel the purchase instead under distant selling regulations for example?
I payed by credit card if that makes any difference.
Thanks
Thanks
