140 mm Fans
im using 4 of the 3000rpm ones on rads the quality is top notch and stupid powerful i keep them on a controller turned as low as they go great performance still but a little on the noisy side. i think i went ott the 2000rpm woulda been the better choice. i think vortez.com reviewed them recently
If you would rather save money and get the same/similar performance/noise then go with the Cougar CF-V14H's or Phanteks 140SP/XP fans. B-Gears also make some sweet 140mm fans.
