140 MM PWM Setup vs Idiot
16 Jan 2009
Hi I working on new build and I planned to connect my Artic freezer pwm fan and 3 140mm pwm fans to my motherboard. I ordered 2 Corsair ML140s 4 pin and an AF140mm. I realised Corsair AF140 is 3 pin so error on my part.
Will I still be able to run my 2 140 4 pins + cpu 140mm cooler fan on PWM and use the 3pin 140mm by plugging it into the default DC mode fan connector and then run in DC mode. The PWM auto detect is CPU system fan connector.
Not sure if worth it to get replacement or not, so any advice appreciated.
Thank you
