Hi there, my friend is looking for a new PC.
Looking for a build of around £1400. It's primarily for 3D work, but also games.
He doesn't need a Case, Windows OS, Monitor, Mouse or Keyboard.
If it helps, the the GPU, the monitor will be running at 1440p.
Everything else is required. It's more about packing a punch than anything else and will be prettied up later, so no cable packs etc. needed
Thanks.
.Thanks.
