140mm AP15?
To me it seems liek the static pressure is too low unless you have them running at high speed, which is probably the case with a lot of 140mm fans. Not realy what you want with watercooling though is it?
cause im running 60mm rads and from the opposite side from the fans I can hardly feel any air movement which im guessing isnt a good thing
Its all game dependant obviously however on my loop which is in my sig in heaven 4 on a average day the cards see around low to mid 50s and cpu peaks around mid to hi 60s but shes not delidded and running [email protected] cards are clocked to a boost of 1215 and mem of 1625 (6500)
Anyone got any thoughts on the yate loon d14sh-12? 2800 rpm and 140cfm yes loud but on a fan controller I should be able to control their bark, Ive read mixed reports about the static pressure of them though some say up to 3.5 at full chat others say nowhere near that
Those fans seem to have different ratings depending on where you look.
2000-2300rpm / 103-140 cfm... Even the manufacturer is honest enough to say that they're loud though :D
Not checked any reviews.
Just looking the blade designs, I'd say that the above two fans that I linked probably have better static pressure.
What's the push pull situation?
Thought about GT's with adaptors?
im running an nzxt switch ive got push pull on 2 out of the 5 fans one on each rad but thats all I can fit. adapters wont work due to the design of the case
I could perhaps adjust the pump/res to add a second push / pull to the front rad but the top rad is maxed due to motherboard and drive bays getting in the way
both front and top are set to exhaust pulling through the rads the 2 fans on show are the push fans, i did run the front as intake for a while but that heated up the internals of the case and the mobo started running toasty
I run my rads as exhausts too (Top=push, Front=Push/Pull).
I found that having a rear intake helped a bit and I could actually feel a difference in the amount of air coming out of the top rad, though I have fewer objects (tubes) blocking airflow from the rear...
Using a TY-140 seemed to be an improvement over the 120mm Alpenfohn fan that was there previously.
Can you feel a difference in the amount of air you can feel exiting the rads (and in temps) if you run without the side panel? I could.
