140mm case fans
10 Jan 2009
Any recommendation for 140mm fans for front intake ? Building my nephew new pc, he would like them to be blue led but its not a must. I'm thinking if cant get good led fans I will just get some led strips.
Yes those are the ones will get if dont go for of go for non led/rbg, I have them on my pc. :) He said he wants blue, guess could always go for rgb and he can set it to whatever colour he wants ? Any particular RGB fans I should look at ? Thank for your help !
Depends what connections his motherboard has rgb , argb or may need a hub but im not that clued up with all that stuff.
Take a look at the fans or could get a bundle with a hub.
https://www.overclockers.co.uk/air-cooling/fans/by-size/140mm-pc-fans?sSort=3
I have the red led corsair ML 140mm as intakes on my case they shift air when need be and the led is not to overpowering.
