140mm fans
28 Oct 2010
Colchester
hello all,
Rite i need some advice from you. Next week i will be water cooling my pc i have everythink now but 2 things and that is 2 140mm fans.....
i have been thinking about THESE. I have a lancool k62 case what takes 2 140mm case fans at the top so these will be under my radiator
what is Black Ice SR-1 360 pulling air through and at the top pushing air will be 3 viper fans.
Are the Enermax fans really good or not? if not case someone recommended me some really good 140mm fans please :D
Thank you
Yeah, they're good. Seen some reviews of the new Enermax fans and they're all top notch apparently. Have a google first though, £20 is a lot for a fan even if it is one of th best.
Overclockers are the cheapest what i can find so far but yeah £20 is a lot for a fan nut i need 2 +postage what makes it £45...
are they any good?
For the £5-6 u buy them for, depending on where from, then yes they are good.
Ok they only run at 1000rpm, but from the sounds of it the vipers will be doing the work.
Plus with that radiator you will never have to go over 1000rpm. But if you wanted faster, they do make them upto 2800rpm, and still the same price.
thank you for that info :D.
I have the Enermax T.B.Silence on my rad and I'm very happy with them. I run them at 100% and they really are silent. They run at 750 RPM which is fine, but may be I could do with more cooling if I went mad with the overclocking.
I also have the 120mm Enermax Lava (bat blade) fans which have a lot of punch. They are running at 32% at the moment and they are audible but only as a low hum. I'm pretty sure I can turn them down more, but I haven't got around to trying that yet.
