- 9 May 2012
- South Wales
hi all
whats the best 140mm fans to buy on market at minute ?
Depends what you want, performance or silence, or both?
Hi back.hi all
+1Corsair ML140 Pro's, those magnetic levitation bearings really are the bees knees. Running 7 in a 780T case and it's so quiet but make sure you run them through a proper PWM circuit.
Any chance I can be cheeky and ask for the best one/s in each category?
I’m looking at the non-pro Corsair ml140 dual pack.
MLs are a very expensive way to go. There are many fans that perform as well or better for less money .. but as I said before, "Depends where / what you plan to do with them."
That is reasonable enough price. I don't know i there are any harmonic vibration issue when mounted in Meshify. Not home atm so can't do much.Front intake for the case meshify c, the two pack of the non-pro ml40 is £23.49(£11.75 per fan) at a competitor.
Noctua 140's here - would recommend strongly (colour aside)
Silent wing 3 are superb. This coming from a long time noctua fan (pun)
