Guys I need help
Looking at getting my first AIO cooler in my new build.
Reading up to get back up to date (M.2's, Chipsets etc) I know what I'm going for. I will OC, but I want to build the best cable managed PC I ever have. I seriously want it looking clean as this is where I've failed before with them looking horrid.
So, I was thinking, I'm getting the NZXT H440 and I'm unsure of the following setups:
Push/Pull 140mm on the rear of the case.
Pull 240/280mm on the top of the case
or being super bold/stupid...
Push/Pull with a 240/280mm on the front of the case (hopefully hidden behind the storage bays as I won't be using them) - the issues with this (BUT I DON'T KNOW IF ITS SUCH A BAD IDEA, HENCE RAISING IT HERE) I see are bad airflow into the case (only 1 fan doing the work pulling in at the front) and then the rear and the 2/3 at the top pulling out and the hot air from the radiator coming into the case. Or could this be reversed with the got air going out maybe? I JUST DON'T KNOW
I do want to use the Alpenföhn green Wingboost fans as the look suits the case colour (black green).
Please, anything would help from the experienced guys here.
Is one of the earlier ideas fine? Or is this "use the front" idea ok either pulling through or pushing out.
Thank you
Thank you
