Akasa Apache Black - I find them one of the best for the amount of air they can shift at low speeds while as quiet or quieter than anything else however they are pretty average at higher speeds and I've found performance a bit hit and miss - about 40% of the ones I've used have significantly worse performance noise wise to the others.
Prolimatech Blue Vortex Blue Wings - do well in a lot of tests but not black.
Noiseblocker BlackSilent Pro Fan PK2 are a good compromise for noise/airflow.
