140mm Wide Rads?
28 Oct 2006
Does anyone know if OC sell 360x140 rads, I couldn't seem to find any (maybe I am looking in the wrong place). I have F51 Suppressor case and want to take advantage of the 140mm mounting in the top for a wider rad.
By 360x140 I'm guessing you mean a 420mm radiator (360 is 3 x 120mm fans / 420 is 3 x 140mm fans). Overclockers do sell a couple but don't have a massive range, so it could be worth a look around some more specialist watercooling sites, although with the 420's there doesn't seem to be as much choice as there is with the 360's.
Yeah my bad I meant 420x140x60 - I can only see slim rads (36mm) in the shop...
Have a shop around, I can't post links on here but Alphacool, Black Ice and Phobya definitely make full fat 60mm thick 420mm radiators. I've not used any of those makes before so couldn't comment on which is best, but I'm sure a few people on here will be able to offer some advice :)
