Hi,
I'm just looking for a little advice...
We've currently got two machines, both running 6GB 1060s with 60Hz 1080p monitors (Dell Ultrasharps).
The first is a Haswell i5 4460, 16GB RAM. This is my old general purpose machine, it runs Windows, Linux, is used for light coding, some database work, remote access, and various other work bits and bobs. Game wise, I'm mainly using it for Total War and other less strenuous games like Grim Dawn, and a bit of Diablo 3 now and again. Nothing too strenuous, really.
My son has a Ryzen 1600, which I've O/Ced to 3.9, with 16GB of RAM running at 3000Mhz. It's a little over a year old now. He's playing R6 Siege, Fortnite, Overwatch, Titanfall 2 etc. So, mainly twitchy shooters.
I'm thinking of splashing out and buying two of these Samsung monitors for Christmas. One for each of us:
https://www.overclockers.co.uk/sams...-hdr-widescreen-curved-monitor-mo-235-sa.html
I'm looking at these as long term purchases that we'll upgrade towards, and realise that the 1060s aren't going to be ideal to start with, particularly for my son.
What I'm wondering is whether or not his 1060 is going to manage pushing 1440p? I know that Freesync isn't going to be of any use to start with, but will it be playable at that resolution? He's more keen to improve framerates than get massive amounts of detail, so will be happy dropping settings to increase framerates.
Second thing I'm wondering about is whether it'd be worth swapping our 1060s out for RX580s, given how cheap they are these days. It seems performance wise they're pretty similar, but we'd get the benefit of Freesync if we switched. Worth it or would it be better to stick with the 1060s for now then jump up to Vega 56 cards as our next upgrade?
Longer term I want to replace the Haswell machine with another Ryzen, and it'll probably be a 2700 or whatever the equivalent 8c/16t processor is at the time. Not sure if the i5 would bottleneck a Vega card at this stage?
Finally (wow... this ended up longer than I expected!) should I be looking to upgrade our power supplies to drive a Vega 56? We've current got a Seasonic Focus Plus 550W Gold in the Ryzen and a Bequiet Pure Power L8 530W powering the Haswell machine.
Cheers for reading if you made it this far!
