1440p 24" suggestions?
5 Aug 2010
Looking to replace monitor following a PC upgrade this year.
Current one is about 8 years old and not worthy of the new PC so one for a swap!
After a 24" 1440p monitor for gaming (just casual). Budget £250-300?
What am I looking at, assuming there may be some cyber monday deals about so looking to purchase soon!
Hmm I'd suggest either sticking with 1080p at that size or going up to 27". Should be some just about in your price bracket; although probably lower end ones. If you stick with 1080p you might well be able to go for a gsync one within your budget as 1080 is so much cheaper. take a look and see what you make of the options.
I'm considering a 1440p myself but want at least 27" or ultrawide if going for them pixels, just haven't managed to pick one yet!
