1440p + laptop help
Caporegime
9 May 2004
Leafy outskirts of London
Not sure if this is even possible, but my dilemma is such:
I have a 1440p monitor with no scaler that uses Dual-link DVI.
I have a laptop that had MiniDP.
I bought a MiniDP to DL DVI adaptor.
The above doesn't work like I had hoped. Windows 10 for the most part does not even acknowledge that the external monitor exists.
In a very specific display setting section, it does note it as TOPSYNC, but trying to extend to it, or set is as primary doesn't work. Cloning is a no-go as the laptop is limited to 1080p, and no scaler means the monitor can't downscale to 1080p.
I can't seem to figure out how to extend, but with separate resolutions, which I know should be possible.
Anyone experienced anything similar?
Not a Hazro 27 inch is it? Had the same, tried loads, wrote custom infs etc. and it just wasn't having it :(
Potalion, guess that's what I get for getting it uber cheap :(
*ponders getting g-sync monitor*
