144Hz and 60Hz Eyefinity (Mixing Refresh Rates Possible?)
22 Oct 2012
Essex
So I bought a 144Hz monitor hoping to use that centrally with two normal 60Hz side monitors - I have the 144Hz monitor working at that rate generally, but when I set up Eyefinity it drops to 60Hz to suit the other monitors. Is there any override for this?
If it matters I'm currently using an AMD Asus 270 X, and although I know its pretty pointless getting the 144Hz monitor, I will be upgrading the GPU to suit (so AMD or Nvidia are possible upgrades to get this working if required).
Cheers!
