Correct. The visual effect of tearing is reduced at 144 Hz but still visible so if it annoys you as much as me, you definitely want GSync or FreeSync.You'll get tearing whenever you have sync off and the fps output doesn't match the monitor's refresh rate exactly, so I suspect what you need is gsync/freesync![]()
I have a Gtx 970What GPU do you have ?
I have a Gtx 970
Cheers mate i will doWell go into the Nvidia control panel and under manage 3d settings change vertical sync to fast if its available.
I use G-SYNC and Fast sync together and there is no tearing when frames go above 144hz.
You need Gsync for that.
When i go into nvidia panel and put it on Fast sync do i have to enable vsync in the game settings aswell for it to work?Well go into the Nvidia control panel and under manage 3d settings change vertical sync to fast if its available.
