14 Apr 2019 at 14:54 #1 tipsy tipsy Associate Joined 23 Feb 2004 Posts 1,393 Location Greenside/Tyne & wear Looking at a 144hz monitor and just wanted to know can it display 144hz via HDMI? This is the cable it will be supplied with.
14 Apr 2019 at 18:08 #2 Bounce Bounce Associate Joined 22 Dec 2011 Posts 2,354 Location UK tipsy said: Looking at a 144hz monitor and just wanted to know can it display 144hz via HDMI? This is the cable it will be supplied with. Click to expand... Short answer no. You need display cable
14 Apr 2019 at 18:08 #3 anthony99 anthony99 Associate Joined 15 Jun 2016 Posts 256 maybe .......a displayport cable would be better
14 Apr 2019 at 18:17 #4 tipsy tipsy Associate OP Joined 23 Feb 2004 Posts 1,393 Location Greenside/Tyne & wear Was just curious as why supply and hdmi cable with a 144hz monitor. Ok so display port cable it is then, so this would be fine with a gtx1070?
14 Apr 2019 at 18:30 #5 Double07 Double07 Associate Joined 10 Jan 2006 Posts 1,835 Location Scotland CAPS_LOCK said: Short answer no. You need display cable Click to expand... Well it does depends on the resolution surely.
