146GB 15K RPM SAS drive replacement
5 Nov 2010
Hertfordshire
Just a shot in the dark really. But does anyone know whether the Toshiba MK1401GRRB will be okay in a RAID-6 array with Dell (Seagate) ST9146853SS drives? Server is R420 with a H710 Mini.
Both drives are 146GB 15K SAS.
If it is not an 'official' dell disk it might show a warning in dell diag pages or monitoring but it should work fine, we replaced all the drives in an r610 with 2.5" wd blacks with no issues
We have a server with non official hp disks in, flags up warnings that I don't think you can disable. Wish we had legit drives!
You could buy a 'reconditioned' dell disk. Try Lamicro.
@bledd
All sorted now but that’s for the reply :)
I found a company that had some original sealed Dell parts including caddies, so bought 3!
