- 18 Mar 2003
Build:
CPU: 15-11600KF (note the F!)
Motherboard: Gigabyte Z590 UD AC
Memory: 2x 8GB Crucial Ballistix BL8G36C16U4B.M8FE1
NVME: Samsung 980 Pro 500GB M.2 2280 PCI-e 4.0 x4 NVMe Solid State Drive
PSU: be quiet! Pure Power 11 600W 80 Plus Gold Power Supply
Cooling: Corsair H100X
Case: Corsair Carbide 175R RGB Mid-Tower ATX Case - Black Tempered Glass
GPU: R7 250X Vapor X 1Gb, HD5450
Issue:
Fails to boot. Fans spin up, Red LED sequence goes CPU ... DRAM ... VGA and then stays lit
Tested:
I have tried two different GPUs (which work in another PC) the 250X required VGA power and that was supplied, the 5450 needs no extra power. Result = Same
I have tried 1 stick of ram and moved to different slots. Result = Same
I unplugged all headers except cooling and fans, I removed the 980 nvme. Result = Same
Possible Issue:
1. The motherboard BIOS when new defaults to onboard GPU. As this is the KF (which does not have GPU) the motherboard will not post. HIGHLY LIKELY?
2. The motherboard has ATX_12V_2X2 and ATX_12V_2x4 in the top left of the board. The PSU only has the 2x4 connecter. It could be that the board will not power even the 5450 because there is no 2x2 cable? Not likely.
Anyone give me some pointers here?
Issue:
Tested:
Possible Issue:
