£150 to spend on case upgrade
27 Feb 2011
Hi All,
I did some work for a friend over the weekend and now have £150 to spend on upgrades for my system. I am mostly looking for a case as performance isn't at the top of my list, whereas looks and quietness are more important!
This is my spec at the moment:
Cooler Master Elite 430 (Inoffensive but much too crowded, no cable management and cheap plastics on the front)
Asus P8P67 Pro
2500K i5
2x2GB Crucial XMS3
Alpenfohn Matterhorn CPU cooler with 120mm alpenfohn fan
1TB Caviar Black (currently empty)
640GB something or other (current boot drive)
MSI 5850 Twin Frozr (noisy at anything above 30% fans)
3 x silverstone 120mm fans (bottom intake, top and rear exhaust), a 140mm alpenfohn fan as front intake, the cheap blue led fan that came with case is side intake
Silverstone fully modular PSU
Scythe Kaze Master fan controller
dvd drive
The PC is more of a hobby machine as I mostly use a Macbook Air as my day-to-day machine, but thinking about doing some light to medium gaming (might need to upgrade gfx card for battlefield 3, otherwise ill stick to xbox), and maybe some photo editing.
Main reason I want to upgrade the case is there is no cable management and its really cramped inside - even with all my fans I still have to crank them up full blast to get cooling similar to other systems.
Had a look at the Corsair 600T and the 650D, something similar to these would be good? 650D is my favourite, but read bad things about noise?
Noise is only an issue with the older fan controller.
Solved on newer versions with upgraded fan controller.
You can also replace the fans with quieter ones still and have change left over from 3150.
650D is the obvious choice for:
1: Discreet yet professional "'business' styling.
2: Cable tidying.
3: Low noise, good cooling.
650D seems to be being quite highly spec'd yet others seem to be moaning about the noise it makes due to neg pressure... Personally I'm unwilling to suggest because of this...
650D is a lot like some of the Lian Li stuff, and the Lancool k9 looks a lot like a 650D, although not sure when it'll be released...
http://www.vortez.net/news_story/lancool_releases_stylish_new_pc_k9_series.html
For £150 you could get a Silverstone Raven - Worth looking at?
kd
Mine is as quiet as a decent spec laptop so I don't really see where the noise complaints are coming from.
Like I mentioned above, I just changed the front intake for something that pushes more air and is quieter and control the fans from the mobo.
If people spend some time with stuff and lifted a finger instead of relying on out of the box experiences then those complaints would not exist :p
kd
The Raven is too big for me, but it isn't bad looking.
Looks like the 650D is winning here, its probably my favourite case on the market at the moment.
I read a thread on here that said you had to cut the front mesh out of the case to get rid of the noise, is this no longer applicable then? Really don't want to have to take a power tool to a case straight out of the box!
what fan did you get?
CoolerMaster Megaflow 200mm.
You don't have to cut the mesh, cutting it gives some more airflow but increases noise a tiny bit with the dust filter detached as the mesh acted as a sound damper with the stock fan.
Can't say for the CoolerMaster though as it's too quiet to tell...
Interesting, as I've said, I can't go on personal experience, just what others have said, but interesting to see what you've said :) Will have to take it into account when suggesting cases :)
kd
well I've ordered the 650D today, will attempt to get everything built into it for the weekend and will post up some pics once done.
Don't know if I can be bothered with cable braiding, could anyone let me know where I can get the bitfenix pre-braided cables from?
kd
That is nice! But why is it 'grey' inside! :(
There are three versions: grey interior (cheapest), black interior without side window, and black interior with side window. Obviously anyone with taste would go for one of the ones with a black interior.
Oh there are? Sweet :D
and lmao.. Yeah definetley :p
Well the 650D arrived at work yesterday but I'll have to wait for the weekend to take it home in the car as there is no way I'm carrying it across London on the tube. :D
I will put up a separate thread on the removal of guts from the elite 430 and sticking them into the new case, don't think it really deserves a project log, just a bit of cable tidying.
