£1500 system
9 May 2012
Aberdeen
Friends son is looking to spend £1500 on replacing his.
So I suggested he could probably go for a 980ti and a 27" 1440 for around £900.
That would give £600 for case, motherboard, memory, cpu and possible cooler.
Any one suggest a full build thanks.
Including operating system?
I've put this together as a place to start, it's got the "ideal" spec, a few minor sacrifices can bring it within budget. For example, if you don't plan to OC, we can drop the CPU, cooler and possibly MB too.
My basket at Overclockers UK:
  • 1 x Acer Predator XB270HA 27" 1920x1080 TN G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red= £389.99
  • 1 x OcUK Kinetic Z1 - Intel Z170 Configurable Skylake DDR4 Gaming PC = £1,224.80
    • Case:Kolink Aviator Midi Tower Gaming Case - Black
    • Processor:Intel Core i5-6600K 3.9GHz (Skylake) Socket LGA1151 Processor - Retail
    • Memory:Team Group Elite 8GB (2x4GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black (TPKD48GM2400HC16DC0
    • Graphics Card:Asus GeForce GTX 980Ti DC3 Strix 6144MB GDDR5 PCI-Express Graphics Card (GTX980TI-6GD5) with FREE Fa
    • Storage Mechanical Hard Drive:Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
    • Optical Drive:Unwanted
    • Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
    • CPU Cooler:Alpenföhn Matterhorn Black CPU Cooler
    • Primary Solid State Drive / Hard Drive:Samsung 120GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E120B/EU
    • Security Software:ESET Smart Security - Trial Key
    • Build Time:Standard Build Systems - Dispatched within 7 working days
    • Warranty:OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour)
    • WIFI:Unwanted
Total: £1,637.89
(includes shipping: £23.10)
