15k sas 3gbps vs 10k sas 6gbps drives
22 Feb 2010
Southampton
we currently use servers with a raid 5 array of 5 x SAS 15k 250GB 3.5" 3gbps drives
we are speccing new servers with a raid 5 array of 4 x SAS 10k 600GB 2.5" 6gbps drives
any one have a clue if this would be faster / slower / the same? (roughly)
thanks!
Access times will be slower but throughput should be better. Though I'm not totally convinced that duel port drives are actually any quicker?
edit - just noticed your going to 2.5" as well, that should offset some of the performance loss going to 10k
Id say a small loss but not enough to worry about. RAID5 isnt the quickest RAID about so I would worry about it. Mechanical Hard drives cant make use of 6gbps it barely uses 3gbps.
For through put and redundancy RAID10 is the shizzle.
It would be slower.
- Firtly you're going from a 5 drive set to 4 drives. This is a drop in overall capability IF you push your drives.
- The 15k drives can do about 180 IOPS (worst case, random), the 10k drives can do about 130 IOPS (slightly more due to the smaller size).
- You won't notice any improvement with the move from 3Gbps to 6Gbps.
If you're putting these servers under any kind of load it may become noticable.
