- 20 Jul 2006
OK need to replace the 80*15mm fan in my Asus Pundit PSU, the stock fan is rated at 27cm@37DB..., but I have found only one fan which is quiet, Sanyo Denk San-Ace, it's Rated 21CFM@21DB, not bad huh? should be enough to cool the power supply, as I'm running a 65Watt AMD X2 4200, 2*DD2 Ram, 1 HD, 1 DVD Writer, 1 TV Tuner, 1 Capture Card, Memory Card Reader..
So what do you think I will notice a big difference in noise compared to stock fan, also will the system be quite/silent?.., considering the only other noise is coming from the Hard Drive..
