- 8 Aug 2010
- Oxfordshire
Below are some ISO 25600 samples from various camera's. Original Raw files were downloaded from DPR, however they seem to be missing 6D & 1DX raws/reviews.
I then converted all the Nefs & CR2s into Adobe raw files (DNG) using their DNG converter software.
In DNG converter settings, I ticked the option to down-sample all the files to 15mp raws. The purpose of this is to end up with raws that have the same output resolution as each other. This will give a more accurate representation of the noise, and better simulates what you would get in the real-world if you made 'X' size prints from each of the camera's.
The raw files can be download below if you want to compare the raws in LR etc.
D4
D800E
5D3
D600
650D
D7000
Samples below @ Lightroom 4 defaults.
D4
D800E
5D3
D600
650D
D7000
D4
D800E
5D3
D600
650D
D7000
D4
D800E
5D3
D600
650D
D7000
