16 bit MS-DOS Subsystem ERROR
8 Jul 2005
A mate of mine is having this problem in XP - keeps getting this error message. I have no idea what program/process is the culprit and was hoping one of you Windows wizards would know what to do.
C:\DOCUME~1\RUPERT~1.SMO\LOCALS~1\TEMP\Surfai~1.exe
The NTVDM CPU has encountered an illegal instruction
CS:0701 IP:0186 OP:637465642e Choose 'Close' to terminate the application
that looks like a spyware problem, the application is running from the temporary internet folder.
use hijackthis to remove the link, and clear his temporary internet cache
Run the usually spyware software aswell, he might have more spyware installed
Thanks
