1600AF overclocking
22 Nov 2010
Never had an AMD CPU before so looking at what overclocking options there are.
Have downloaded Ryzen master and played around.
Overclocked to 4ghz @ 1.275 running cinebench and Aida 64 benchmarks for stability. Im assuming that once I have some stable results in the ryzen master software that I transfer this over to the bios?
It's a hot day so ambient temperature is high and the CPU stays around 80c
Just wanna check I'm doing stuff right or if there is other ways which are better?
Seems fine, but try to invest in better cooling. I take it you are still on the stock cooler?
From memory I think I used 1.35v for 4.3Ghz with mine, but it's under a custom water loop so temps were never an issue.
Also, try to stay under 1.375v for long term use.
ive managed to adjust some more and am on 4ghz @ 1.25 73c
Using a cryorig H7 cooler.
