- 26 Sep 2013
- West End, Southampton
Hi guys.
I've currently got 16GB DDR4 Team Group 3600mhz (2x8gb) but I'm noticing in a few of my games now, especially Cities Skylines and Planet Coaster, I'm exceeding 16GB at times due to the amount of mods I run. So, if I wanted to throw in another 2x8gb of the same memory, populating all 4 dimms, that shouldn't be a problem should it with the dual channel memory controller? both groups of dimms will still work in dual channel correct? And do you think I'll still be able to run 3600mhz XMP with 4 sticks?
thanks.
thanks.
. Can you not just manually set the timings so each pair mirrors the other?
