16GB DDR4 for OC'ers bundle
Hey all,
I'm struggling to find some RAM for a bundle I'm about to order.
It's the i7-6800K with Gigabyte x99 gaming 5p
https://www.overclockers.co.uk/giga...ore-cpu-and-motherboard-bundle-bu-028-gi.html
The motherboard compatibility list has drawn me to G.SKILL 2*8GB (F4-3000C15Q-16GRR).
That ok for a half decent overclock, maybe 3.8 or 4Ghz?
Cheers,
Andy
Not sure what you are asking?
You won't get 3800-4000Mhz out of that kit on the bundle you are purchasing. You are best off purchasing a quad channel kit rated at 3200Mhz.
I'e got 2 Gaming 5P boards and both have worked with the two different sets of Team Group RAM. The fastest was 3000 DDR4 though.
Check with OCUK as they should know.
