Hey all,
bought some used stuff off a fella on gumtree, very upfront sound bloke, i7 920, gigabyte ex58-ud5 rev 1, 12gb ram and a corsair h50 in a coolermaster 690. gave me the box for the ram and said there was an extra 4 that he couldn't get working.
so i looked it up, said gigabyte board apparently supports triple channel with 4 sticks in this configuration:
i cocked up and put it in the actual slot 1/2/3/5 resulting in 16gb 8gb usable then realised i was an idiot and put it in the proper slots and got 16gb 12 usable. did more searching, problem hunting so here's a quick list of what i've done
here's a photo from in the bios showing it recognizes the stick in slot 5 but it's not usable
http://i.imgur.com/jJ1MRCK.jpg
i was on bios version f12 and with the 16gb 12 usable itd boot into windows, once i upgraded it to f13 id get a "detecting dram size" on boot and it'd do that 3 or 4 times and crash before finally booting. took out one stick and put it back in triple channel mode and its working fine. as of now i'm out of ideas, the only thing I found that I couldn't do was to do with memory remapping as I couldn't find anything about that in the bios. any ideas/help/etc would be appreciated
full specs:
i7 920 at stock speeds
gigabyte ga-ex58-ud5 rev1
16gb corsair vengeance ddr3 4x4GB (cmz16gx3m4a1600c9b)
sapphire radeon hd 6850
corsair h50
windows 7 ultimate x64
evga 550w
- tested all sticks seperately (all working)
- bumped up dram/qpi voltage
- swapped all sticks around in different slots etc
- loosened the heatsink screws since apparently over tightened heatsinks were causing memory problems on x58 boards
- set clock speeds manually
- tried xmp profile
- set clock speeds slightly lower
- reset cmos/overclock to default and tried
- disabled memory limit in msconfig
full specs:
corsair h50
evga 550w
