This is slowly but surely driving me insane.
I was under the impression that ziphone would do all the work, so I plugged my 1.1.3 Touch in, updated using iTunes then used ziphone to jailbreak it, only to get a recurring message on the Touch screen saying "bsd root: md0, major 2".
This seems to be a common problem, but i've fllowed every walkthrough I can and it still won't work. It's supposed to take under 5 minutes but I've spent 3 up/downgrading and jailbreaking for the same message to keep on popping up. Has someone else had this problem? Can ANYONE help me out?
Had 1.1.3, iTunes> 1.1.4
ziphone to Jailbreak, got stuck.
Restore mode, tried again. Same
Restore mode > downgraded using already downloaded 1.1.3 fw package. Tried again, got stuck.
All the how tos save one just show me how to get it back to 1.1.3, but can I upgrade at all?
Looked around, found http://forums.macrumors.com/showthread.php?t=442639 and tried
Exclamation working 1.1.4 16gb ipod touch
If you're getting a BSD error when trying to jailbreak your iPod Touch, complete the following to get your iPod working and jailbroken with 1.1.4 firmware. This was done on a mac and you'll need the 1.1.3 firmware update
1. connect sync cable to 'broken' iPod
2. open iTunes
3. hold down sleep/wake and home buttons until screen is blank
4. release sleep/wake button ONLY when screen is blank
5. release home button when iPod appears in iTunes
6. press option key + Restore button and select the 1.1.3 firmware file
7. wait for restore to complete
8. go through iPod setup wizard, uncheck automatically sync and click sync to synchronize nothing
9. click on check for update and update the iPod to 1.1.4
10. wait for update to complete
11. click sync to sync nothing
12. Eject iPod and close iTunes
13. Disconnect sync cable from iPod
14. hold down sleep/wake and slide to power off
15. hold down home button and connect sync cable
16. release home button when iTunes logo appears on iPod display
17. open ZiPhone
18. select Jailbreak
19. click Start
20. wait for jailbreak to complete
No chance. Help me out, I'm kinda frustrated
Anyone have any advice?
Many thanks!
2. open iTunes
17. open ZiPhone
19. click Start
Many thanks!
