- 17 Nov 2010
Hi,
I am looking for a 17" laptop between £800-1000. Currently i have a 15" Aspire 5920 which has a core 2 duo (2Ghz), 4GB Ram, ATi 3650 and a Blue-ray drive.
The problem is that the performance is slow and the battery has died so i am looking at a new higher spec 17" laptop but i am not sure which one is the best to get.
I will be mainly using it to do software development, hence the larger screen size, but i would like to be able to run some games on it.
I was looking at the MSI GX740 but it only has an i5 430M which may be slow when running my developer tools.
HP have a 17" laptop with an i7 but only an ATi5650:
http://h40059.www4.hp.com/uk/homelaptops/product.php?id=WR197EA&experience=direct
for £995
Although i think the graphics card is a little weak, but it does have an i7, i have read a few reviews regarding the GX740, implying that the screen is not up to much which is no good for me as i will be using it all day.
can anybody suggest any other options?
Thanks
Andy
for £995
Thanks
Andy
