I am looking for reccomendations on a PSU to fit the fractal arc mini.
From the products webpage:
It would need to have the wattage to handle a possibly 580 SLI upgrade, ROG gene V MB, intel prosessor and a small WC system, with some over clocking headroom as well as 2HD, 1 SSD and a blueray writer.
Efficiency would be nice, noise IS importaint.
I am thinking around 800w gold rating?
And ideas appreciated!
BUDGET EDIT:
Around 125. possibly more for quality improvements.
(The case)Supports PSU's with a depth of maximum circa 170mm, when using bottom 120mm fan location.
BUDGET EDIT:
