£180 Card
17 Oct 2006
Aviemore, Cairngorms, Scottish Highlands
Need a card to drop into a system with a Intel i5 2500k at stock, 8Gb Ram and 600watt psu.
Not bothered if its AMD or Nvidia ;)
Max budget is £180
Get the Powercolour 270X Devil. It is the same price as the Sapphire and as fast, but you get game codes worth £30 you can sell in the MM. Warranty is covered by OcUK as well
Thats a good idea, i have a Powercolor 7870XT, nothing wrong with it, its very stable and overclocks well, but then it would. its an AMD reference PCB.
My only complaint is that the BIOS has voltage unlocking locked to their own 'Power Up Tuner' app, which is not so good.
I don't know if they still do that, i asked Gibbo but he hasn't given me an answer.
