1800xt > 1900?
3 Dec 2004
Hi all,
I not a huge gamer with the only main game I play being oblivion. I am quite happy with my x1800xt (256mb), 3800x2 system but my card struggles a liitle when using textures pack (oblivion). I only game at 1024 so an expensive modern card is wasted on me.
The 1900 (512mb) seems like a good upgrade for me. Do you agree? What card is the range is considered the best?
The X1900XT 512mb
The X1900XTX 512mb
The X1950XT 512mb
The X1950XTX 512mb
are the ones I would recommend.
I have one and it runs Oblivion on 1600x1200 with good textures
But I would pay no more than 70ish for the above, if you want to spend 100plus consider 3850 pro 512mb/ 3870XT
surly if u want better quality the look at the HD3000's as they will offer more performance than the X1900's
the card below will offer higher performance than a x1900, and can play new games, for roughly £20 max more than the fastest 1950 on oc
http://www.overclockers.co.uk/showproduct.php?prodid=GX-166-SP&groupid=701&catid=56&subcat=416
Thanks for suggestions, i never realised new 'performance cards' were so cheap. However the card lined above is a 256mb, the card I am upgrading to MUST be 512mb+ due to the texture packs I use in game. I think I could pickup a second-hand 512 1900 for around 65ish but would be willing to spend £100 on a new card, if I could get a better performing card in budget then that then I would go with what ever you suggest.
Thanks
