1800xt = To a...
9 Aug 2004
Milton Keynes
My 1800xt (PCIE) is dying basically :(, what would it be equal to in todays market?
Just need to work out what to replace it with dont need it to be much better really
http://www.overclockers.co.uk/showproduct.php?prodid=GX-171-OK&groupid=701&catid=1914&subcat=2077
This card is nearly as powerful as the 8800GTX which is around 2x the performance of the X1900XT so for just a little over £40 for more than double of the performance of your current card when you only want something as good as is a done deal. If you want something bigger then please say and remember to check your PSU is going to be up to the job.
I would go as far as saying it is equal to the Intel on-board graphics, or may be a touch better by comparing it to the very crappest of video cards.
The x1800xt could not even play Oblivion at high settings and I ditched it in 2007 as it was loud, only had 256mb of memory and was just not powerful enough for modern games.
Pretty much any card Overclockers sell will be better than this.
