I've discovered, after many years of instability, that my Gigabyte Z87-D3HP doesn't like 4 sticks of RAM and has been the cause of many headaches (i've tried many of the 'fixes' but the only fix that works is taking out 2 sticks, doesn't matter which 2).
So i'm intending replacing my 16GB of Patriot 4x4GB 1600MHz with a 2x8GB setup.
I've found some Kingston HyperX Fury 1866MHz for a reasonable sum (i.e. cheaper than the 1600MHz sets I had been looking at) but just want to check it won't cause me any other untoward issues and it will simply slot in and the BIOS will sort out what it needs to so that everything runs happily?
If it makes a difference the CPU is an i5-4670K (not overclocked because the PC was never stable at stock, now I know why I might clock it a bit!). Would it make overclocking any more or less easy with 1866MHz in there rather than 1600MHz?
