19" TFT suggestions
31 Dec 2006
Cardiff
I'm looking for suggestions for a 19" - 21" TFT to run my Dlink DM520 media player, all I want it for is to mount on the wall by the player so I can view and slect the tracks that I want to play.
It must be VESA mountable and it must also have S-Video Input and or Composite Input.
I was thinking for getting the Dell 2407wfp to replace my 20" Dell that I'm using now but that would set me back £500 and to be honest it is a bit much just to get a monitor to see what music I wan to play.
I don't really want to spend a fortune just something reasonable.
doggo
Yes it works fine,
I'm using a Buffaol 500Gig linkstation, my Linksys wireless router and the DM520 all work together fine.
My music is feed to my hifi via an RCA lead. I would say the sound is very slightly flat but there again it may just be me being hyper critical. There is no shortage of connecters on the back of the DM520 so what ever your setup you should be fine.
doggo
MrLOL said:
sorry to take this thread slightly OT
but ive been thinking about getting one of these. Are they any good ? and crucially, have you managed to get it to play stuff from a NAS ? ive got a uPnP NAS and want something like this to play my downloads on my TV
as for a recommendation id be using this tbh
http://www.overclockers.co.uk/showproduct.php?prodid=MO-052-SA&groupid=17&catid=276&subcat=
but does the samsung have s-video or composite inputs, also is it VESA compatible.
the samsung is definitely more of a computer monitor, than a computer monitor come TV.
for s-video etc.. your looking really at the 24" and above. Not sure what 19" has them.
not sure if ifs VESA wallmountable either, as its designed to be used a computer monitor, it doesnt really need it
sounds to me like you'd be better off buying a HD ready 20" LCD TV and using the vga port on it to connect your PC.
