- 15 Aug 2006
Hi,
Just recently upgraded and installed everything today.
I installed fear and had a go at it, but I was disappointed with the results.
On 1024x768 4xaa 8xaf it barely seemed playable, jerking when I turned a corner etc. So I lowered this but the problem persisted.
I looked at the card settings in the ati control centre and the card is running at 500mhz vpu and 594mhz gpu. This seems slower than it should be, and the card is pretty hot at 55 degrees idle (god knows what it was at during 3d mark).
Other games seem to play well but the fear demo doesnt.
i'm running a 3700+ 939, 2gb of ram (2x1gb) and a connect3d 1900xt
Advice appreciated
Sjoehanson
[edit! is there a way to check if memory is working dual channel?]
Advice appreciated
,Sjoehanson
