Hi there, have built a PC for a mate and put the above GFX card in, and he is finding that the temps look a bit high with the stock cooler - sitting at about 63 degrees idle.
Was looking at a couple of alternatives and was wondering whether they would be any good and if anyone here uses them, as the reviews look promising.
http://www.overclockers.co.uk/showproduct.php?prodid=SY-002-AR
http://www.overclockers.co.uk/showproduct.php?prodid=HS-025-ZA&groupid=701&catid=57&subcat=787
http://www.overclockers.co.uk/showproduct.php?prodid=SY-008-ZA&groupid=701&catid=57&subcat=787
Cheers very much
Edit - Can this be moved to Graphics section please, cheers very much
Cheers very much
