1GB GTX 560 Ti for max settings??? TF2/CS:GO
29 Apr 2003
London, Forest Gate
1GB EVGA GTX 560 Ti - If purchased.
Will I be able to play on max settings, 1920x1080 resolution for;
Team Fortress 2
CS:GO
I want to spend as little as possible, needed for two PC's.
Money is tight, I need to buy it for two PC.
Can I play on maximum setting on Team Fortress 2 and CS:GO ?
EDIT: Gregster, do you have a 1GB 560 Ti?
Remember the money is tight, I need to purchase for two computers.
It will only be used for Team Fortress 2 and CS:GO, nothing else.
I used want to play on maximum settings for those two games.
So it will play on maximum settings, at 1920x1080 without any problems for these two games.
£68 is a good price for a new card 560 Ti.
My processors are Q9550.
It can handle it, but I'd look at second hand market if really going 560 ti route. It's not worth £68, and isn't far off the cost of a slightly better second hand 660TI.
Yeah, I'd try and aim for something a little better if your going second hand.
As for maximum settings, it depends what fps you're expecting. My monitor's native resolution is 1200p, and my 7970 is the first card I've had that can run CS:S (I don't really play GO) with maximum settings and with the frames I desire. Some people won't need a high end card to get the fps they want, so like I say, it does depend what performance you need.
