Turn off pc, and install only 1 stick.
Either use control panel> system properties>general tab
or download CPU-z, and check under memory tab.
Alternatively if your bios is set to display the post screen (and not some graphics instead), then it will tell you there too. I wouldnt go by what it says on the chips, it could be double sided ram.
