Caporegime
- 7 Apr 2008
- Lorville - Hurston
Hi all.
I am looking to possibly build a new rig again after i discovered some damaged bent pins.
I will try and fix them tonight but doubt i will get very far so as a backup plan i want to build a new rig with a 1k budget.
Here are the specs of my existing system:
I dont mind reusing some of the components above like the PSU, case fans and of course my graphics card.
Type of stuff my Computer will be used for:
I am pretty much out of the loop when it comes to what the latest tech is but from my brief search, socket 2011/x99 boards copped with the latest i7 haswell e i believe is the latest and greatest at the moment?
Also now uses ddr4 ram?
Is there any new sockets coming out in the horizon like within a month?
i dont want to purchase old socket 2011 if there is a new socket(broadwell? Skylake?) coming out real soon.
Also, want to be able to Overclock past 4ghz. i believe the last few cpu's like ivy bridge etc can easily OC to 4.5ghz range?
Thanks in advance
- 2x 980 GTX SLI cards
- 12GB 1600mhz DDR3 Ram (4x3)
- Corsair AX850 Gold PSU
- Lian Li A7010 case(falling apart)
- 2 crucial SSD's(128 and a 256gb one)
- 2 Nocta 120mm Case fans
- couple of mechanical Hdd's
- 30 inch Dell 3010 2560x1600 res monitor
- 24 inch Dell 2410 1920x1080 res Monitor(i use dual monitors)
- Editing High res DSLR quality Images
- Coding
- Gaming at 2560x1600 and above(may get a 4k monitor in the future)
- Photoshopping
- Video encoding at 1080p res or higher
Thanks in advance
