1st attempt to overclock.
30 Aug 2006
Im totally new to overclocking, although i have been reading about it for well over a year. Ive been looking for various beginners guides and i have found the guide below.
I trust this forum and its readers more than anyone else. What i would like is your opinions on is weather or not you think i could do what the guide says and get away with it and if you agree with the alterations to bios.
The guide was written with a near same setup as i have.
I would test this with MemTest86+ and Prime95.
E6300
1gig Corisar XMS2 (Soon to be 2gig)
7900GS
Stock cooling + 2 extra fans in the case.
DS3
Here it is:
Advanced BIOS Features
- Disable CPUID Max to 3
- Disable No-Execute Memory Protection
- Disable C1E
- Disable TM2
- Disable EIST
- Disable Virtualization Technology
PC Health Status
- Disable Smart Fan Control Method
Motherboard Intelligent Tweaker (M.I.T.)
- Press Ctrl+F1 for Advanced Settings
- CPU Clock Ratio (CPU Multiplier) at 7x
- CPU Host Frequency (FSB) at 430MHz
- PCI Express Frequency at 100MHz
- Disable CIA2
- System Memory Multiplier at 2.00 (1:1 Ratio)
- DRAM Timing at 5-5-5-15
- DDR2 OverVoltage Control +0.2V (2.0V)
- FSB OverVoltage +0.2V (1.4V)
- (G)MCH Voltage +0.1V (1.55V)
- CPU Voltage at 1.274V
Regards.
You'll probably need a bit more vcore. Maybe ~1.4v.
Other than that, the guide's pretty much spot on.
