1st Build - experiencing CPU Temperature problems (80c+ at idle!)
4 Jun 2003
IOM - made in Stoke
OK guys really need help here,
Me and my friend are working on my new build, see the spec below,
OCZ 4GB (2 x 2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK) £109.99
Gigabyte 3D Aurora Black No PSU with Side Vent 1 £68.99 (£68.99)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK) 1 £79.99 (£79.99)
Intel Core 2 Quad Pro Q6600 "Energy Efficient 95W Edition" 2.40GHz (1066FSB) - Retail 1 £149.99
Gigabyte GA_P35C_DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard 1 £64.99 (£64.99)
Leadtek GeForce 8800 GTS 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail 1 £181.99 (£181.99)
2 x Western Digital Caviar SE16 500GB SATA-II 16MB Cache - OEM (WD5000AAKS)
Samsung SH-S203NBEBN 20x20 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black) - OEM 1 £18.99 (£18.99)
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM - 1Pk (66I-00788) 1 £59.99 (£59.99)
After installing the hardware we've attempted to install Vista where it's powered down during installation, presumably because of CPU heat. We checked in the BIOS and it's recording 80c-83c which seems ridiculous!
We've resat the stock cooler and applied new thermal paste (after cleaning away the old) but the temperature is not dropping. Has anyone else had similar experiences with this and can make any suggestions. The cooler seems to sit tightly so shouldn't be an issue there.
Any suggestions welcome!
Matt
Vcore 1.275 at the moment (not been touched). It just went as high as 90c! I'm presuming it must be a contact issue although it seems to be just fine and fits snuggly :(
We've just resat it and reset fan contorl to manualand it's down to 25c now haha. We'll get through the windows install and let you know if there are any other probs.
Thanks for the input fellas.
regards, Matt the n00b. :)
