1st PC build problems
21 Nov 2020
Hi guys having some trouble with my new PC build. Put my system together today, it boots up fine and I can enter the bios. I used the windows media creation tool to put windows 10 on a Fat32 drive and selected it as primary boot order in the bios. The trouble is, when I save and exit all I get is the MSI splash image, cut in half and going off the edge of the screen. Any help would be appreciated! All I want is to put windows 10 on my new PC and it’s driving me nuts. Not sure how to get past this! I updated the bios before I started, so wondering if it’s something I’m doing wrong with the bios.
Try a different usb stick or try a different usb port, sure i read some issue about usb sticks and usb2/usb3 ports, just went through a new build with msi board this week the splash image was cut in to a pile of rows that didnt line up on my first boot, but it did go straight to windows install, first time for me. sound like its nearly ready to go
Turns out I did have the stick in the flashback port. Moved it over one, but still doing this. Please see :
https://imgur.com/gallery/izQjhQm
The screen just went black, with a small white underscore, and then gone to the option for entering BIOS. Pressing Delete doesn't do anything
https://imgur.com/gallery/iCKPIVF
izQjhQm
Feel like I'm at my wits end here!! Usb 2.0 16gb formatted to Fat32, with windows media tool on it. I put the drive into a usb slot on back of the motherboard and power on. I make sure the BIOS is set to UEFI and the usb drive is priority number one in the boot order. I save and exit the BIOS but instead of loading windows I am faced with this strange distorted picture!!
https://imgur.com/gallery/rBvaZBU
Also once you have working installation drive, set it as second drive after the drive your installing too, otherwise it starts the install sequence again when you reboot.
Sorry for the late reply. Been fiddling today and once the BIOS recognised my m.2/ssd as the boot drive i selected that as priority one. Windows installed successfully and the computer now works
